by DarrellJ » Wed Feb 15, 2017 9:39 pm
I think I solved the problem. I am pretty positive that it is/was the AUX setting on the radio. Yes, you heard that right.
I was looking at all the fuses that had anything remotely to do with the console. While doing that I noticed that the radio and instrument cluster itself were on the same exact fuse. Fuse 137 btw for my vehicle.
The second I seen that it suddenly dawned on me where the problem probably was. I very seldom use the AUX port unless I'm on a road trip. However, earlier that day I had tested out a CB via the AUX port. And sure enough, when I turned on the vehicle and looked, the radio was still set to AUX. Like I said, I don't listen to the radio that often...lol. I switched it back to normal radio mode and I've not seen the flashing and clicking since.
Btw, several months back when this issue first popped up, I had been on a road trip and was using the AUX port. So, the device I was connecting must have glitched or something. Or it was just the radio messing up on it's own. Anyway, I remember the guy that tested the battery asked me to turn everything in the van on in order to see the effect on the battery. This included me turning on everything from the AC to... yep, the radio. Which I switched to normal radio mode at that point. So, while the battery did need to be replaced, it wasn't what "fixed" the issue... it was me turning off the AUX.
I still need to turn the AUX back on... maybe put a device to it... in order to verify. I just haven't gotten up the nerve yet. I'm already 99% sure based on the above. And trying to recreate the problem could make things worse... if not hurt the device I connect. I may decide to leave well enough alone. I seldom use the radio anyway.
