Front brake upgrade
Front brake upgrade
Postby NC53 » Sun Feb 05, 2017 10:43 pm
I'm thinking about bigger front brakes on my 2007 connect.
What would be a good upgrade which will clear 16 inch alloys?
I assume mk3 Mondeo discs/pads/calipers/carriers would work.
Be interested to see what others have done. Thanks.
NC53
Re: Front brake upgrade
Postby Eskimo » Sun Feb 05, 2017 10:45 pm
I've got Mondeo brakes on mine but you have to machine the caliper to get the spacing right
Eskimo
Postby darkbluevanman » Mon Feb 06, 2017 7:27 pm
Jags have same pcd... bet they have some bigger disks.. done loads of bikes with diff caliper set ups, using brackets all doable depends what you skill is and availablity of materials :) ... don't find the std brakes too bad!
darkbluevanman
Postby NC53 » Mon Feb 06, 2017 9:11 pm
What's involved in machining the caliper?
My mate fitted the mondeo set up to his Fiesta and had to grind the calioer slightly to clear the wheels. Is that what you mean?
NC53
Postby blue estate » Mon Feb 06, 2017 9:28 pm
What about the mk2 Focus diesel 300mm disc and calliper also should clear wheel
mk2.5 Focus zetec 1.8tdci 09 hatch
mk4 Escort estate 1.3no 1.4 yellow
My other car is a 44t MAN TGX 480 tractor unit
blue estate
Postby NC53 » Mon Feb 06, 2017 9:46 pm
Ok mk2 Focus is potentially another option i hadn't thought about.
NC53
Postby blue estate » Mon Feb 06, 2017 9:57 pm
NC53 wrote:Ok mk2 Focus is potentially another option i hadn't thought about.
Make sure it's the 300mm ones , the carriers have 300 cast in them
blue estate
Postby Nel69 » Sun Jun 10, 2018 9:35 am
Hi guys did the tdci focus carriers work :D
Nel69
Users browsing this forum: vanavitch
