by sbt » Sat Feb 11, 2017 1:14 pm
hi all thanks for the replies . that's interesting that the 110ps is higher geared I thought they were all the same gearbox the van I have is a limited edition so it as a green arrow within the rev counter that tells you when to change up . not that I rely on this but when the arrow illuminates and you change up it vibrates its nuts off hence the reason I think there is a fault . all the vibration is definitely coming from the nearside front also something else I have noticed is the vibration seems a lot less when the van is cold 3 or 4 miles into a journey and it gets progressively worse . I have replaced all engine mounts which made it worse there was nothing wrong with the original mounts so I put them back on
