pestguard1 wrote:Quick question , rear break pads , ( disc breaks ) I replaced rear break calipers on my van TDCI 1.8 , but the holes in the cylinder do not match the pins on the pads , ie pad pins too far apart , so breaks are pushing on the pins , not the pads , any sugestions , can the pins be ground off , or is it new pads also................also the pads that have the spring attached to top of the pad , does this go against the piston , or other side of disc
