loses power when going up hill
Postby david_1 » Sun Mar 12, 2017 11:44 am
transit connect 13 plate
starts runs well
it seems happy at 90 to start with but as it warms up it feels like the limiter is kicking in. but if I depress the clutch the engine will rev right up
anyway as come to any hill needing more power it just slows down the longer i driver it the slower it gets
have a said anything that make sense to anyone ????
thanks
David
david_1
Re: loses power when going up hill
Postby blue estate » Sun Mar 12, 2017 11:52 am
What hp is it and what weight you carry
72plt MG 5 ev estate Battery car
blue estate
Postby david_1 » Sun Mar 12, 2017 12:19 pm
1753cc not much weight this has just started happening was running fine last week
david_1
Postby g-man » Sun Mar 12, 2017 12:46 pm
more info will help......is it in good nick with clean filters, is clutch slipping, is it smoking more, have u checked round all air delivery pipes for splits/leaks, good idea to get fault codes read if nothing obvious shows
g-man
Postby david_1 » Sun Mar 12, 2017 12:50 pm
nice clean van its not the clutch, I lifted the bonnet and looked hoses but found nothing. oil and water levers ok
it justs slows down when it should be going faster :)
david_1
Postby david_1 » Tue Mar 14, 2017 4:18 pm
ok van still doing same but only after a long drive, drove 100 mile each way yesterday at about 48 miles it started playing up. not accelerating up hills in fact it slows down but then speeds back on the flat or going down hill.
just talking with a mechanic type guy he suggested I check the vacuum hoses ? anyone else think this might be the problem ?
david_1
Postby david_1 » Thu Mar 16, 2017 8:07 pm
anyone ? I drove it to bristol drove fine for the first 100 miles
then started losing power going up hills... I cant be the first person to have this fault can I ??????
david_1
Postby david_1 » Mon Mar 20, 2017 8:23 pm
ok so got it connected to a computer today, says low pressure on fuel ( or something close )..... new fuel filter, think its now fixed.... will up date in a few days after ive driven it.
david_1
Postby david_1 » Fri Mar 24, 2017 8:30 pm
MY VAN IS FIXED :)
was just a dirty fuel filter..... well dirty fuel :(
david_1
Postby blue estate » Fri Mar 24, 2017 8:35 pm
david_1 wrote:MY VAN IS FIXED :)
And all it cost was a fuel filter , so that 2p less a litre some times is not worth it
blue estate
Postby Graham Taylor » Sat Mar 25, 2017 10:21 am
Regular maintenance always pays in the long run (especially when going up hills! :-) )
Graham Taylor
Postby david_1 » Tue Apr 04, 2017 1:36 pm
my van has full service history... you can not plan for a filter change with each tank full :)
david_1
