07 connect stereo not working.
Postby mike En » Wed Mar 15, 2017 1:51 pm
As above my 57 plate work van's radio has stopped working, I've changed the standard one for a Kenwood cd with aux input, however I think one of the bullet connector has come unplugged and shorted behind the dash popping the fuse.
Anyway my question is where is the fuse bloody for the it ?
Little sticker on back of glove box doesn't show anything resembling much, and tbh I dot think it tally's up with what's in there anyway !
I've plugged the original stereo back in and still no power at all and have tried the Kenwood stereo in my camper and works as it should.
Any help is much appreciated as the 2 hour each way journeys to work are doing my head in !
mike En
Re: 07 connect stereo not working.
Postby mike En » Wed Mar 15, 2017 1:58 pm
I've just counted the fuses and there's space for 11 fuses in each of the 3 rows.
The fuse location sticker on the back of the glovebox shows 12 per row !
mike En
Postby Marcelladog » Thu Mar 16, 2017 12:08 am
Try fuses behind glovebox
Marcelladog
Postby APH » Thu Mar 16, 2017 10:42 am
mike En wrote:I've just counted the fuses and there's space for 11 fuses in each of the 3 rows.
That fuse layout is actually correct, it just doesn't work visually as fords have used it to show more than you can actually see in the box :lol:
You need to read it like this:
The BLUE section is row 1 (top) when you look at the fuse box
The GREEN section is row 2 (middle) when you look at the fuse box
The ORANGE section is row 3 (bottom) when you look at the fuse box
And just to confuse matters, the extra one on the end in PURPLE is actually on the BACK of the fuse box out of site and does the Hazard warning lights.
The two blanks on the end are spare labels for lord knows what. :wink:
mike En wrote:As above my 57 plate work van's radio has stopped working, I've changed the standard one for a Kenwood cd with aux input, however I think one of the bullet connector has come unplugged and shorted behind the dash popping the fuse.
The radio fuses are here:
The left one is permanent feed, the right is ignition switched feed.
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby g-man » Thu Mar 16, 2017 12:26 pm
you're right, ford don't help much........good info should be a sticky
g-man
Postby mike En » Thu Mar 16, 2017 4:37 pm
Thanks guys that's helped me loads, when I'm home I'll chuck a new fuse in there !
God knows what the hell they where thinking with that so called fuse diagram ! Bloody ridiculous lol
mike En
Postby APH » Mon Mar 20, 2017 10:15 am
mike En wrote:Thanks guys that's helped me loads, when I'm home I'll chuck a new fuse in there !
Did you get it sorted :?:
Andy :D
(\__/)
(")_(")
this is bunny
APH
