mk2dk wrote:Just changed mine, not the funniest job. If a garage is prepared to do it for 200, I'd let them have the job. Problem is they run over the fuel tank, which has to be lowered to gain access. In front they run between the chassis and crossmember, which also has to be lowered. They probbably won't change them the entire way to the ABS block, as they normally are ok. I ended up using 12 meters of copper pipe, which also comes at a price.
With that in mind, 200 is a very fair price.
