connect folding passenger seat
Postby Willb33 » Wed Mar 22, 2017 9:44 pm
hi all,
i have just bought a 14 plate connect that has the 3 front seats setup. but the pull tab (that comes out the seat at shoulder height) to fold down the seat nearest the window is missing. does anyone know if there is another way to fold down the seat or if this can be fixed.
any help or advice would be great
many thanks
Willb33
Re: connect folding passenger seat
Postby swishvan » Tue May 23, 2017 9:52 pm
just checked mine and it seems simple enough to put a hook pick down the hole on the top of the seat find the lifter and release the seat, then just loosedn the trim cover off at the corner and attach some webbing to the
pull, the red tag operates a bar inside he seat which releases a catch at the hinge at the base of the seat, you can also lift the base upward to gain access to the bottom hinge and flick it up with a screwdriver to release the hinge lock
there are no locks that connect to the body, like a focus rear seat, its totally in the hinge hope this helps
Alan
Vehicle Trimmer
swishvan
