Connect ABS...
Connect ABS...
Postby darkbluevanman » Wed Apr 05, 2017 7:26 pm
not had chance to get under proper on the van yet... but whilst swapping the wheels I noticed a wire going to the rear drum... at 1st I thought some kind of pad warning!... but then realised after looking at wheel bearings, it could be abs... but I thought only abs was on rear disc'ed cars... what's the wire for??
darkbluevanman
Re: Connect ABS...
Postby Boghopper » Wed Apr 05, 2017 9:38 pm
It is for the ABS and traction control, if fitted. It monitors the tone ring which is part of the rear wheel bearing.
Boghopper
Re: Connect ABS...
Postby paul2012 » Sat Apr 08, 2017 12:52 am
darkbluevanman wrote:not had chance to get under proper on the van yet... but whilst swapping the wheels I noticed a wire going to the rear drum... at 1st I thought some kind of pad warning!... but then realised after looking at wheel bearings, it could be abs... but I thought only abs was on rear disc'ed cars... what's the wire for??
All Connects from 2006 onwards have ABS as standard :wink: 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Re: Connect ABS...
Postby darkbluevanman » Mon Apr 10, 2017 6:17 pm
It's an 05, rear drums, but has abs light on dash... dearer wheel bearings LOL
darkbluevanman
