2009 TDCI oil from exhaust
Postby Soupy » Wed Apr 26, 2017 10:47 am
Hi,
My connect blew it's head gasket, oil getting in the water. This resulted in the turbo being starved of oil and destroying itself. I replaced the head gasket and turbo (second hand from the bay of E) and got her fired up. Now I'm getting thick grey/white smoke and oil from the exhaust.
Where do I start? New engine? Troublesome as all I can get are KKDAs and that would mean keeping the turbo (IIRC).
Any suggestions appreciated.
Soupy
Re: 2009 TDCI oil from exhaust
Postby Soupy » Fri May 26, 2017 11:50 am
Anyone?
I bought a new/refurb turbo and new oil cooler.
Still getting oil from the exhaust...
Soupy
Postby ned » Fri May 26, 2017 12:10 pm
Is there any oil in the intercooler? If so you need to clean it out also the boost pipes and there may be some in the exhaust itself
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Soupy » Tue May 30, 2017 1:19 pm
Thanks for the reply, I have found the problem, there is a crack in the head!
Next question -
It's a R3PA engine code, will I need that exact head or will others fit?
Thanks.
Soupy
