I wasn't offering to do it!
At 109K it should be on original clutch and they can last a lot longer, but not always, depends on the driver(s).
Get a few quotes for 3 piece clutch and crank shaft seal.
Is it 90 or 110? Check with Fords if yours has 'Dual Mass Flywheel' They are expensive if you need to replace that as well.
https://www.fordpartsuk.com
