Second battery
Second battery
Postby travelling man » Mon May 15, 2017 3:30 pm
First post,beware of the newbie....
I have just bought myself an 05 plate T230 LX TDCi,with the general idea of creating a 'stealth' camper.
I'm a little confused about how to connect a liesure battery for overnight use,in the past with boats I've used a split charge relay to isolate the 'start' battery from the 'domestic' but this smart charging system has me confused.
Looking at this gadget;
http://www.ebay.co.uk/itm/301544923367? ... EBIDX%3AIT
Will it be suitable,please?
:D
'05 Transit Connect T230 LX TDCi Engine buggered in Spain,replaced with a T200 base 12 plate in white which also buggered it's engine in Spain!
2nd Connect had breakdown insurance and an engine swap, see how long it lasts.....
travelling man
Re: Second battery
Postby travelling man » Tue May 16, 2017 8:37 am
I emailed the supplier.
They say that the item above does not work with smart alternator's and I require this unit;
http://meadotech.shop/victron-energy-25 ... -640-p.asp
That's just about my entire budget!
I'm now thinking either no beer chiller or a seperate,solar powered system for 'behind the bulkhead'.
What have others done,please,I cannot possibly be the first to come across this issue!
travelling man
Re: Second battery
Postby Boswell » Tue May 16, 2017 12:18 pm
I've used one of these for the past 3 yrs charging a 110Ah leisure battery with no problems.
https://tinyurl.com/ChargeControl
2007 230L
Boswell
Re: Second battery
Postby Piglet » Tue May 16, 2017 12:43 pm
According to:
http://www.petercoopercarrepairs.co.uk/ ... arging.htm
We are only supposed to use Silver Calcium batteries with our Ford Smartcharge.
But I don't think mine is.
But I did have to replace the alternator last week!
Piglet
Re: Second battery
Postby Boswell » Tue May 16, 2017 12:47 pm
Not using a silver calcium battery as your main battery does not harm the alternator but does shorten the main battery life.
Using the charge controller I have linked to above, you can use any type of 2nd battery
2007 230L
Boswell
Re: Second battery
Postby travelling man » Tue May 16, 2017 8:18 pm
Thank you,I just knew there had to be a simple answer!
:D
travelling man
