Hi all
Just finishing off a clutch and gearbox change in the above.
The new clutch kit came from LUK and was a 3 piece, cover, plate & CSC, the problem is the CSC has 2 x hydraulic lines and the old ones, (old gearbox and replacement used gearbox) both have a single hydraulic line.
I have spoken LUK and they advised I needed an adaptor to turn the twin lines from the CSC to a single line to connect the supply line.
I then spoke to the clutch supplier and they advised the same and sent me one out. The "adaptor" has arrived, LUK part number: 418 0395 10, but this is just a single hydraulic line.
Has anyone else come across this and is the hose that has been sent actually what I need? And if everything is correct could someone point in the right direction to actually installing it?
Thanks in advance
MAS
