Evening all.
So i have purchased a set of 18" mondeo ST alloys. I know I need to get specific nuts for the alloys as the nuts that I have for the steel rims shouldn't be used as they will damage the alloy wheel.
So i know I need the following -
PCD – 5 x 108
Thread Size – M12 x 1.5
Hex Size – 19mm
Seat Type – Tapered
My question is, do I need the alloy wheel nuts with Captive Washers on them or not? How I am supposed to find this out?
For example, I have found this information - Ford alloy wheel nuts are different to many standard nuts. These nuts are designed specifically for Ford alloy wheels. There is a captive washer giving the seat a diameter of 28mm, approx 4-5mm wider than most other nuts.
Thanks,
