2011 transit connect abs light, brake light
Postby gsmith » Sat Jun 10, 2017 5:30 pm
Hi,
First time on forum. I have been having issue where abs and battery light flashes gauges go haywire radio stops working. Brought to shop they replaced alternator. Still does this periodically. Mechanic not able to figure out. Is anyone familiar is this problem. Thanks
Gary
gsmith
Re: 2011 transit connect abs light, brake light
Postby nardi » Sun Jun 11, 2017 6:41 pm
There is a wiring loom breakage on this Connects.
Check the wiring from the alternator plug to about the clip that holds the loom to alternator body.
There is normally a corroded smart charge wire, on my van, it was the read wire.
Good luck wit it.
nardi
Postby gsmith » Sun Jun 11, 2017 6:55 pm
Nardi,
Thank you for info! Will Check.
Gary
gsmith
