Hi all.
I've got a 03 plate connect that has standard steel wheels but I'd like to upgrade them to ford alloys.
I have the chance of a set of 17" rims from I believe a Mondeo.
My question is will these fit?
I use the van for work so it does carry a fair amount of weight at times & as the standard rims are 15" I want to know if fitting bigger rims will have the tyres rubbing on the arches?
If this is the case is there any way I can get around this? Such as stiffer suspension Springs etc??
Hope someone can answer this question
Thanks in advance
