About time you binned that stupid question mark
Like you new avi thing though
Reminds me of your mother
Mike wrote:JayKay3000 wrote:every panel uncovers more rubbish repairs.
You’re not going to be the first person to do repairs on the cheap.
Enzo200500 wrote:I fitted a bumper kit from a certain Transit 'bits' supplier.
Not genuine Ford!
Turned up and looked ok qaulity.
Then had exactly the same problems as yourself.
Step had to be glued on, then it came loose, so I wrapped large black cable ties around it.
The end caps would only stay on after I bolted them with s/steel nut and bolt through the bottom fixing point!
The plastic tabs were all brittle and nothing aligned correctly with the original ford mountings. Basically crap plastic copies that do not fit. Thanks TP's.
Should have brought genuine Ford parts......
