How much do garages charge to change a rear bumper
Re: How much do garages charge to change a rear bumper
Postby bigjohnthomas » Sat Jul 15, 2017 7:06 am
About time you binned that stupid question mark
Like you new avi thing though
Reminds me of your mother
bigjohnthomas
Postby JayKay3000 » Sat Jul 15, 2017 5:08 pm
Mike wrote:
JayKay3000 wrote:every panel uncovers more rubbish repairs. :(
You’re not going to be the first person to do repairs on the cheap.
True, but there is doing it cheap and doing it right :wink:
Anyway. Here is the current results. Looks OK from a distance. Phoning around ford to find some oem fasteners for the side clips since these side bits seem to be a bit of a pain to get on. Going to try heating them to see if I can shape them a bit. I saved the fasteners for the plastic top cover so I'm going to pull the bumper off myself next weekend. Should have just told the garage to release the nuts and payed them £20. Guess I learn things the hard way.
Be nice to finish it and wait for the next thing to fail. Probably the turbo :roll:
JayKay3000
Postby Enzo200500 » Tue Jul 18, 2017 6:25 am
I fitted a bumper kit from a certain Transit 'bits' supplier.
Not genuine Ford!
Turned up and looked ok qaulity.
Then had exactly the same problems as yourself.
Step had to be glued on, then it came loose, so I wrapped large black cable ties around it.
The end caps would only stay on after I bolted them with s/steel nut and bolt through the bottom fixing point!
The plastic tabs were all brittle and nothing aligned correctly with the original ford mountings. Basically crap plastic copies that do not fit. Thanks TP's.
Should have brought genuine Ford parts......
Enzo200500
Postby JayKay3000 » Thu Jul 20, 2017 1:17 am
Enzo200500 wrote:I fitted a bumper kit from a certain Transit 'bits' supplier.
Not genuine Ford!
Yep, pay more, but only have to buy it once! I'm glad I got a second hand OEM front bumper. It had some minor damage, but it fit perfectly!
JayKay3000
