ford connect vacuum hose
Postby kevdand » Mon Jul 03, 2017 4:55 pm
hi
just got a 1.8 tdci connect on 55 plate
on inspection we have a vacuum pipe it run out off top off relay on the bulk head then runs towards the turbo the just hang and cant see where it is suppose to go it looks like it should connect to another pipe any ideas
thanks
kevdand
Re: ford connect vacuum hose
Postby liteace » Tue Jul 04, 2017 11:45 am
Top pipe on solenoid goes to air filter box, look behind the large inlet hose you will see the connector there
liteace
