Hi my transit connect 2009 model is over heating. The coolant fan isn't working. I checked fuses and relays but they are good. Connected the fan with direct supply and fan worked. Checked the wire for resitor (connected to the radiator) but there is no supply when key is turned on the ingition.
What else i need to check.
My problem is that the van is for my work and at the moment I really need it in hand:(
Many thanks
Mark
