Is it Possible to find out where my engine came from?
Postby connectboy » Thu Jul 13, 2017 10:58 pm
Does anybody know if it's possible to find out the registration plate of a focus from an engine number? I'm asking as I've just found that the engine in my connect is a F9DA type from a focus .
I'd like to find out the registration plate of the focus So I can look up the mot history to get an estimate of the milage the engine has done .
Ta
connectboy
Re: Is it Possible to find out where my engine came from?
Postby liteace » Fri Jul 14, 2017 12:09 am
Yes maybe, give us the complete engine number and I'll see what I can do
liteace
Postby dumper » Fri Jul 14, 2017 7:49 am
If the engine is running ok not burning oil and smoking and quiet I'd just given it a full service and timing belt kit and if water pump is driven off belt also do that .the 04 focus I had I put full belt kit and pump on it at 92000 I know the lad I sold it to its know done 165000 and sill going strong.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby dumper » Fri Jul 14, 2017 7:56 am
Also just another thought I always hpl a vehicle before I buy it useing vin and engine number I would hate to check up after buying it find out the engine is stolen
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby connectboy » Mon Jul 17, 2017 10:04 pm
Thanks for the replys, I've just sent you a pm liteace. The engine is running ok now, I had to change the injectors as soon as I bought it which was a bit annoying but the more I drive it the better the engine seems to be feeling, I'm wondering if the engine has been off the road for a while and is a bit clogged up inside.
I've given it a oil and filter change, only used halfords own oil as I'm treating it as an engine flush so will do it again soon but with better oil this time.
The vans got 167 on the clock so I'm hoping the engine has less
connectboy
Postby liteace » Mon Jul 17, 2017 11:35 pm
connectboy wrote:Thanks for the replys, I've just sent you a pm liteace
I Can't get PM's on this forum, sorry
liteace
Postby connectboy » Tue Jul 18, 2017 9:31 am
Ok, my engine number stamped on the side of the cylinder head is F9DA2R48829. If you could find anything out about it , it would be greatly appreciated.
connectboy
Postby cabrown89 » Tue Jul 18, 2017 10:55 am
Sorry to hijack this thread but I have a Honda S2000 engine that I dont know the origin of. I have always wondered if it was possible to find the donor car info from the engine number. Basically I wasnt to make sure the car wasnt stolen.
Are you able to do this liteace or can you only do fords?
Or anybody else able to help
Sent from my D5803 using Tapatalk
cabrown89
Postby paul2012 » Wed Jul 19, 2017 5:12 pm
connectboy wrote:Ok, my engine number stamped on the side of the cylinder head is F9DA2R48829. If you could find anything out about it , it would be greatly appreciated.
Won't be able to find MOT history. Engine is NOT from a UK registered vehicle :!:
Focus 1998-2005, 1.8L Lynx Diesel TC(115PS), Moondust Silver (Metallic)
VIN Number: WF0NXXWPDN2R48829
Primary Features
Build Date: 30.10.2002
Vehicle Line: Focus 1998-2005
Body Style: 4 Door Estate
Version: Series 35
Engine: 1.8L Lynx Diesel TC(115PS)
Transmission: 5-Speed Manual Trans - MTX75
Drive: LHD FWD
Axle Ratio: 3.41
Emission: 2000 EEC (EEC 7)
Air Conditioning: Automatic Air Conditioning
Territory: (+)"SI"
Paint: Moondust Silver (Metallic)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby connectboy » Wed Jul 19, 2017 11:34 pm
Thanks for the info Paul, really appreciate it. Interesting discovery that it's got a forgine engine in it, but a shame it means that I can't get the history.
I guess my van has spent some time abroad, during its 12 year life!
connectboy
Postby liteace » Thu Jul 20, 2017 10:24 pm
Or the focus the engine come out of was driven back to the UK from abroad, loaded up, spain by the looks of things, and then scrapped due to dvla's wanting paperwork to get its UK plates that doesn't exist on a vehicle of that age
liteace
Postby connectboy » Fri Jul 21, 2017 11:44 pm
Yep good point hadn't thought of that possibility. I've got no paperwork with the van other than the V5 , so I've got no idea of its history
connectboy
