Can anybody help I've just changed my master cylinder on my clutch and have bleed the slave I have a good solid Pedal but I still can't engage gear? Please tell me it's something simple I'm missing???
Thank you I've been using a bit of kit where you use tyre pressure to push the fluid through (not great) and the pedal technique the pedal is soft and gets harder as I push down? I've pumped quite a bit of fluid through now it's cost more than the part
