I've 'converted' my connect into a 'stealth' camper.....
Installed a battery in the rear and a battery to battery charger on the cab side of the bulkhead.
Now,I need a feed for the battery to battery charger....first thoughts were the rear of the fag lighter socket,but how do I get to it?
Haynes suggests that the lower storage tray 'slides out'...mine seems to be fixed at the back.
Or would I be better approaching the ignition switch?
Do not,really,want to run a 10/15a wire direct from the start battery if there's a neater way of doing it.
Do not be shy,all ideas and methods welcome!
