Hello
2014 Transit Connect LWB. I ran over a piece of tire and within 30 seconds the check engine light came on. The code that came up is P1633 and its hard set, cannot clear it, only 2 symptoms I can detect is that sometimes its a little hard to start and I can no longer set the time and date on the clock and the time chances extremely slowly. We put the car on a lift and inspected the whole undercarriage for damage but nothing was detected, we checked fuses to ECM (32 and 33) both are good. Any suggestions?
Thank you.
