Boost gauge
Boost gauge
Postby mk2dk » Sun Aug 27, 2017 5:46 pm
Hi all
Today I've fitted a boost gauge to the Connect, mostly because I had it lying for years. Made a test drive and it seems to be working fine.
Boost is coming in fast and peaking at 1.10 to 1.20 bar, does that sound ok for a 2003 1.8 TDCI 90HP ? Don't know how precise the gauge is, it's definately not the most expensive :D
mk2dk
mk2dk
Re: Boost gauge
Postby mvirdee » Tue Dec 19, 2017 6:59 pm
Hi
Thats cool!
Have you any pictures of the install please mate?
T200 Limited 110
mvirdee
Re: Boost gauge
Postby liteace » Tue Dec 19, 2017 8:38 pm
My 06 TDCI is blowing a tad over 2 bar but not at full load, your gauge maybe is set so atmospheric pressure shows zero
so atmospheric pressure @ aprox 1 bar + your 1.10 - 1.20 charge pressure = 2.10 ish
Thats OK
liteace
Re: Boost gauge
Postby mk2dk » Wed Dec 20, 2017 7:01 pm
[quote="mvirdee"]Hi
Thats cool!
Thanks[/quote
Picture from the garage, instrumet ligths on. Think the gauge is ment for a petrol engine, since it has a negative boost area below 0. The Connect never has negative boost, as it dosn't have a throttle butterfly as a petrol engine. Night time driving it looks really nice :D
mk2dk
mk2dk
Re: Boost gauge
Postby ned » Wed Dec 20, 2017 7:40 pm
The gauge has boost one way and vacuum the other (negative boost as you call it) depending on how you plumb it in :wink: N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
