connect tddi fault codes
Postby bozza » Tue Sep 12, 2017 7:10 pm
hope someone can help
van cut out today,felt like running out of fuel,
fault codes
p0515
p0149
p1669
p1563
p1664
p0335
p0216
p0622
p1632
bozza
Re: connect tddi fault codes
Postby karl » Tue Sep 12, 2017 8:32 pm
Cam belt snapped
karl
Tranny Lover!!!
Postby bozza » Tue Sep 12, 2017 8:37 pm
karl wrote:Cam belt snapped
just been out and looked in oil filler when cranking engine,camshaft turning...
bozza
Postby karl » Tue Sep 12, 2017 9:10 pm
well you have hard pump codes
p1664 and p1563
and cam and crank codes
p0149 and p0335
crank is turning then the pump is knackered
i would be taking the timing cover off to make sure the belt isnt worn
karl
Tranny Lover!!!
