Intercooler Inlet Hose Bracket Goes Where?
Postby axxeman » Thu Sep 21, 2017 12:31 pm
Hello chaps, my bracket (as per the thread title) was broken and the guy who was fitting a new hose for me took it off the block so I could get another one. Unfortunately, he didn't show me exactly where the bracket bolts to the engine block or the correct orientation. Could someone take a picture to help me refit this part please?
The van is a TC 2004 1.8 TDCi
Many thanks.
Greg
axxeman
Re: Intercooler Inlet Hose Bracket Goes Where?
Postby Piglet » Thu Sep 21, 2017 10:19 pm
You mean Ford 5220606 ?
Piglet
Postby axxeman » Thu Sep 21, 2017 10:26 pm
Piglet wrote:You mean Ford 5220606 ?
I don't recall the number Piggy, it's the bracket that goes beneath the hose on the right hand side of the engine when you are stood at the front of the van ...
axxeman
Postby axxeman » Thu Sep 21, 2017 10:28 pm
... and bolts onto the end, or near the end, of the block.
axxeman
Postby Piglet » Thu Sep 21, 2017 10:35 pm
That's the fella, I can't find a photo but it slips under a bolt down the RH end of the block.
Search that part code on Ebay for the bracket.
The rubber bushes are expensive from Ford but £6 for 4 on on Ebay
eBay item number: https://www.ebay.co.uk/itm/222047233537&seller=&toolid=10018&26138432" rel="nofollow">https://www.ebay.co.uk/itm/https://www.ebay.co.uk/itm/222047233537
Piglet
Postby axxeman » Thu Sep 21, 2017 10:38 pm
Piglet wrote:That's the fella, I can't find a photo but it slips under a bolt down the RH end of the block.
I have all the bits, I just do not know where to fit them ...
axxeman
Postby g-man » Thu Sep 21, 2017 10:54 pm
g-man
Postby axxeman » Fri Sep 22, 2017 12:27 am
g-man wrote:http://fordtransit.org/forum/download/file.php?id=17102&mode=view
Ah. That looks like it is a photo of a later model than mine as the hose is slightly different. I can see the top of the bracket though and it appears to be more on the side of the block rather than the end. Oh how I wish that I had taken more notice when the old one was removed. Trouble is, the chap lives 50 miles away so I can;t just "drop in". The bottom of the bracket appears to have a tongue that obviously locates somewhere in order to keep it in the correct orientation ...
EDIT. My hose has the fixing on the other side more like this;
http://www.moibbk.com/gallery/model-207/ford-transit-connect-engine-1.jpg.html
axxeman
Postby axxeman » Fri Sep 22, 2017 12:44 pm
Worked it out now in the daylight with a little guidance. Thanks all.
axxeman
