Transit connect immobiliser flash turns but no start
Postby Johnny finney » Wed Sep 27, 2017 8:39 pm
Hi im new to this forum i have a question my 2004 transit connect has an immobiliser issue it turns over but no start and immobiliser flashes i have bought a new key had it programmed in and still no start i have had it plugged in and says immobiliser issue... theres no one around who has a clue why it is happenning i hope someone can help me please because it is boggling my head now and i dont know which way to turn with this :/
Johnny finney
Re: Transit connect immobiliser flash turns but no start
Postby geekshow » Fri Jul 06, 2018 6:21 pm
Did you get any result with the immobiliser Johnny?
I'm having similar issues on my 04 Connect. Was running fine but now doesn't start and immobiliser light flashes quickly when ignition on. Battery and fuses all good, same symptoms with spare key. Disconnecting battery and leaving key ignition on for several minutes doesn't seem to make a difference. Planning to check the fuel pump wiring, but a bit stuck other than that.
geekshow
