Interior light doesn't come on when you open doors.
Postby Transdoc » Sat Sep 30, 2017 3:54 am
Hello all, I have a 2012 transit connect xlt and the interior light doesn't come on when you open any of the doors.It can come on when you manually turn it on.Have any of you come across this before?
Transdoc
Re: Interior light doesn't come on when you open doors.
Postby Altransit » Sat Sep 30, 2017 10:24 am
This may or may not be any help, but there were some posts on here a while back about a similar problem, and it was solved by pulling a fuse for the BCM, letting it power down, and then refitting. This allows the BCM to reset :)
You may need to have a search around to find the relevant posts :|
I'm not sure if disconnecting the battery for a few minutes would achieve the same effect, but possibly worth a try :?: :?
Postby Piglet » Sat Sep 30, 2017 3:37 pm
I had this, but it was just the fuse, can't remember which though.
Piglet
Postby Transdoc » Sun Oct 01, 2017 3:38 am
Thanks for the input,but it turned out the relay was missing.
Transdoc
Postby Altransit » Sun Oct 01, 2017 9:16 am
Good result 8)
Can you tell us which relay it was :?:
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
