I'm stuck - remote locking 2010 Connect
Postby JumpingJacks » Fri Oct 06, 2017 12:02 pm
Hi all, I've been having a go at this for a number of weeks during my spare time and have searched extensively on here although theres not much info on the 2009-2013 connect remote locking issues. I've made some progress however ild really appreciate if someone can help me get over the final herdal.
My fob stoped working so I tried the programming guide on here by Paul2012 (thanks paul) and although I got the chime from the dash I wasn't getting the chime when I pushed the key fob buttons. From a previous poster on here i knew i needed to check if my remote key was sending aRF signal to the van so I tuned my analogue tv to 433mhz and pushed my remote and nothing happened. I tried a key from my brothers car and when I pushed it I could see on screen his key was sending a signal so I knew my key wasn't sending a signal. I guessed that when changed the key battery last time I must have disturbed the metal prongs around the battery so I gently adjusted them put the key back together, tested on the tv and could now tell my remote is sending a signal. So back in the van I went and started the programming sequence. I got the first chime from dash to indicate its in programming mode and then my face lit up when I heard second chime when I pushed the key fob lock button so I exited programming as per guide but I get no response from the remote locking which is weird as I know the for sending a signal and the van can read it.
Forgot to mention the central locking works fine in drivers door with the key(only keyed lock on van- also its a hykee replock)
Old be very greatfull if there is anything anyone can think of that may help as I'm worried if the drivers lock fails I'll be completely locked out of the van
Many thanks gents
Transit Connect 2010 TDCI SWB T200 75
50,000 miles
EGR Blank and Delete
K&N Pannel filter
VanTuner Remap :D
Focus Air Box and Snorkel (awaiting fitting)
JumpingJacks
Re: I'm stuck - remote locking 2010 Connect
Postby JumpingJacks » Sun Oct 08, 2017 2:42 pm
So I've been out to the van today and I've checked all the small fuses both in the passengers fuse box and the engine compartment and there all fine. My heads telling me its an electrical issue but I really am out of my depth with this and don't want to unplug things which may cause any damage.
If any one has ideas on what else I could check
50,000 miles
K&N Pannel filter
VanTuner Remap :D
JumpingJacks
Postby Altransit » Sun Oct 08, 2017 2:50 pm
Had something similar on a 2009 Focus, and that was fixed by locating the BCM, and unplugging the cables, and then re-plugging them in :?
Costs nothing, may be worth a try :idea:
Postby JumpingJacks » Sun Oct 08, 2017 7:14 pm
Thanks for your input, thats a good idea I haven't tried that :idea:
Would you happen to know where its located on my 2010 connect as I start sweating when I see Munch's of wires :lol:
50,000 miles
K&N Pannel filter
VanTuner Remap :D
JumpingJacks
Postby Altransit » Sun Oct 08, 2017 8:28 pm
On the Focus, it's in/above the passenger footwell, but it could equally be on the drivers side on a Connect :idea:
Postby JumpingJacks » Sun Oct 08, 2017 8:56 pm
Brilliant, i'll look up a picture of the part online so i know what im looking for and check those places in the morning and update the post. Fingers crossed
Cheers :D
50,000 miles
K&N Pannel filter
VanTuner Remap :D
JumpingJacks
Postby paul2012 » Mon Oct 09, 2017 5:12 am
On 2009-2013 Connect they have a GEM module instead of BCM.
GEM module is located behind fuse panel on N/S (passenger side) behind glove box.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby JumpingJacks » Mon Oct 09, 2017 1:31 pm
Thanks for chipping in with the info 8)
I've removed the glove box and the fibre panel below to get a look. Am I right in thinking I need to unplug these cables behind the passenger fuse box as you look up behind it. I can see 5 sets of wiring looms going into what I'm assuming is the GEM module. It would appear the colour coordinated, looking at it the colours read from left to right Grey, Green, Blue, Grey then Brown. Should I unplug them all or just a specific loom?
50,000 miles
K&N Pannel filter
VanTuner Remap :D
JumpingJacks
Postby Altransit » Mon Oct 09, 2017 2:03 pm
Just unplug them all one by one and re-plug one by one. make sure that you know the radio code first :idea:
Postby JumpingJacks » Mon Oct 09, 2017 7:02 pm
Great, I have the radio code which is handy although old just like to check weather you would advise disconnecting the battery first
Thanks for your help it would be amazing if this sorts it out 8)
50,000 miles
K&N Pannel filter
VanTuner Remap :D
JumpingJacks
Postby JumpingJacks » Sat Nov 11, 2017 11:15 pm
Quick update
I disconnected the battery and unplugged the looms as advised but unfortunately it made no difference. I'm going to get a new remote key as I've noticed that if I push above the left side button it's sending a signal to the tv so I suspect my remote key is buggered. When I get the new one I'll update the topic
Cheers
50,000 miles
K&N Pannel filter
VanTuner Remap :D
JumpingJacks
