P0403 code 2014 Ford Transit Connect
Postby tvrepairbiz » Thu Oct 19, 2017 11:48 am
Keep getting a P0403 code even after replacing the EGRvalve. Did use an original one. 2.5 engine, 75000 miles on it. Mostly comes on at take off, Not as much in S verses D. Connection seams to be OK. Any info would be greatly appreciated.
tvrepairbiz
Re: P0403 code 2014 Ford Transit Connect
Postby Altransit » Fri Oct 20, 2017 4:00 pm
2.5 engine in a Transit Connect :?:
Connect would be a 1.8 TDDi, 1.8 TDCi, or the much later 1.6 or 1.5 TDCi :)
Postby FordDriver » Fri Oct 20, 2017 9:21 pm
USA Connect models have 2.5L duratec with AT. :D
All you gotta do is Go Further! Transit mk6 2.0/Mondeo mk2 1.8
FordDriver
Postby karl » Fri Oct 20, 2017 9:28 pm
p0403 would be related to the eger valve if it has one
are you sure its a 2.5 :shock:
either way
it is still an egr valve fault
karl
Tranny Lover!!!
Postby tvrepairbiz » Fri Oct 20, 2017 10:40 pm
Yes I know but even after puting a new factory valve in I still get it.
tvrepairbiz
Postby karl » Sat Oct 21, 2017 7:14 pm
tvrepairbiz wrote:Yes I know but even after puting a new factory valve in I still get it.
then the wiring needs looking at mate
pull the loom apart could be a broken wire :(
karl
Tranny Lover!!!
Postby tvrepairbiz » Sat Oct 21, 2017 8:31 pm
I here you, was told the PCM is located in the wheel well on the drivers side for us here in the US. Do you know?
tvrepairbiz
Postby karl » Sat Oct 21, 2017 8:42 pm
tvrepairbiz wrote:I here you, was told the PCM is located in the wheel well on the drivers side for us here in the US. Do you know?
yes mate
i done a ford focus the other day and the pcm was behind the passenger wheel arch over were you are will be driver side :D
karl
Tranny Lover!!!
