Hi, I've searched the forum for answers but to no avail,
I recently upgraded from my 06 plate tddi Connect to a 10 plate tdci, I was wondering if anyone here has had any issues with 'Hill Start Assist', When I first mentioned it to a local mechanic I thought he was joking having it fitted to a little Connect.
Anyway my problem is even on the flat I sometimes struggle to set off due to this, almost as though a caliper is sticking, If for example parking in a space at the side of the road, pull up and start to reverse in and as manovering the van when letting off the footbrake it often takes a couple of seconds before it will set off, If it is the hillstart function is there a sensor as surely it should only work on an incline, not on the flat! Is there any way of switching it off altogether as I've never had to use such in all my years of driving different vehicles varying from cars to Hgv's.
Thank you.
