The starter relay in engine fuse box does not energise when key is turned to cranking position, all lights on dash stay on, milage reads 88888888, immobiliser light working correctly, battery checks out with heavy duty tester.
Power is getting to relay coil but not will not energise. I put a test light from the other side of the relay coil to earth and it lit up when I turned the key and starter motor started cranking.
I removed the test light and it stopped cranking.
Any suggestions will be welcome.
