fuel pump
fuel pump
Postby Spikey19531953 » Wed Nov 15, 2017 7:15 pm
Hi all,
Hope you guys can shed a bit of light on my problem
I have taken my connect 2006 tddi to my local garage after i had fuel pump problems. ive got it back after repair and it runs rough on idle along with when i put my foot on the accelerator softly it judders like mad, its fine when i put my foot down turbo kicks in and flys like a rocket with out a problem.
It feels like the timing is out but garage have said they haven't touched the timing belt and i never had this problem before the pump was taken off and put back on
thanks in advance spike.
Spikey19531953
Re: fuel pump
Postby karl » Thu Nov 16, 2017 3:51 pm
they are lying
you have to remove the belt to take the pump of on these and a new belt should be put back on
karl
Tranny Lover!!!
Re: fuel pump
Postby Boghopper » Fri Nov 17, 2017 8:02 pm
As Karl says. The pump pulley has to be removed to get the pump off so they must have messed with the timing. Sounds like the old garage tip-ex and 4" nail to lock the cam, timing job.
Boghopper
