07 Connect EML (P0380)
Postby T i m » Thu Nov 16, 2017 5:02 pm
Hi all,
Daughters 07 Connect came up with the EML the other day so I plugged my Forscan OBD lappy in and found a few codes and (saved them, shown below) and could clear all but one (P0380)?
However, the EML light then went off and I believe has stayed off since (couple of days now).
I appreciate most these codes could be old but I'll post them all (pre clearing) in case they might suggest to someone something that could do with some closer inspection?
Cheers, T i m
===PCM DTC P0380-68===
Code: P0380 - Glowplug control circuit
Additional Fault Symptom:
- Invalid Signal
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
Glow Plug Circuit
Short circuit
Open circuit.
This DTC may be caused by :
Possible causes are:
Relay control circuit
Glow plug relay
Malfunctioning EDCM
===END PCM DTC P0380-68===
===PCM DTC P0490-E1===
Code: P0490 - Exhaust Gas Recirculation Control Circuit High
- Signal is Above Maximum Threshold
Status:
- Malfunction Indicator Lamp is On for this DTC
This DTC is set when the following condition occurs.
The EGRV position sensor value is consistently higher than the desired set value.
EGR valve short circuit to battery positive.
Exhaust Gas Recirculation Valve
For further diagnostic information refer to the appropriate section of eTIS.
===END PCM DTC P0490-E1===
<snip>
===IC DTC P0000-66===
Code: P0000 - Unrecognized fault code
- Signal is Below Minimum Threshold
Status:
Module: Instrument Cluster
While using DLM, check for the following possible faults:
Check for an intermittent electrical fault.
Lightly wiggle on the component and connector while monitoring signals. Take care not to bend or twist any connector as this will cause damage.
Continue to monitor signals and look for sudden changes in values.
Starting at the component, wiggle and pull each component wire.
Wiggle and pull small isolated sections of the wiring harness.
Inspect connectors for signs of damage, water ingress, corrosion, etc.
===END IC DTC P0000-66===
===IC DTC C1210-0A===
Code: C1210 - Right Front Outlet Valve Coil Circuit Failure
===END IC DTC C1210-0A===
<snip>
T i m
Re: 07 Connect EML (P0380)
Postby g-man » Thu Nov 16, 2017 7:59 pm
i had probs with g/plugs last feb.....2 had gone open circuit and blown a 60amp, 1 had melted and the other was carboned up.......they had a hell of a job getting them out, going to have a new set when $ is due this feb :mrgreen:
g-man
Postby T i m » Thu Nov 16, 2017 11:49 pm
g-man wrote:i had probs with g/plugs last feb.....2 had gone open circuit and blown a 60amp, 1 had melted and the other was carboned up.......they had a hell of a job getting them out, going to have a new set when $ is due this feb :mrgreen:
Thanks for that g-man, we'll give the low plugs a check over.
Would /do these 1.8 lumps actually need glow plugs in the sort of temperatures we have seen so far? I ask because I know if I didn't give my old Rover 218SD (1.9 Pug lump) a few seconds of glow plugs it would really rattle and clatter for a good few seconds?
Maybe the Connect puts and holds them on automatically for a while?
Cheers, T i m
T i m
Postby Kenton » Fri Nov 17, 2017 10:24 am
I would like to know the answer to this too! I had all 4 plugs replaced last year after it was found that ALL 4 were not working! The van, although started on the button, was smokey.
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Mondeo Inner Door handles & vents
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby liteace » Sun Nov 19, 2017 5:33 pm
Glow plugs in modern diesel engine are to reduce emissions at cold start
Please don't send me PM's, i can't access them, when I try I get this:
You are not authorised to send private messages
liteace
Postby T i m » Sat Dec 09, 2017 3:24 pm
Kenton wrote:I would like to know the answer to this too! I had all 4 plugs replaced last year after it was found that ALL 4 were not working! The van, although started on the button, was smokey.
Well,
I've just got round to looking at this and think I've found what might be a / the problem?
Where the engine bay loom joins the heavy wire that feeds the glow plugs they join on some plastic looking fitting that bolts to the front of the block and provides a threaded stud / terminal that a ring terminal on the end of the feed wire bolts onto, a bit like an alternator connector or a very old ignition coil. ;-)
Pre noticing that this connection / fitting was melted and that the stud would just lift out easily, I measured no volts on the glow plugs (glow plug light on dash). After pulling this stud out and pushing it back in again (I'm not sure I should be able to do that?) I saw ~14V on the glow plug bus (with the engine running) and a bit of smoke coming off around said connection.
So, is this device *just* a connector, a way of taking the heavy wire from the glow plugs and connecting it the the loom or does it contain something subtle (like a fuse etc)? Is it melting what it's designed to do under some fault conditions (like a shorted glow plug)?
Checking on here it looks like it is a known (if not common) issue but with no real pointers to the exact cause?
https://www.fordtransit.org/forum/viewt ... 54&t=95077
Cheers, T i m
T i m
