Hi all,
Daughters 07 Connect came up with the EML the other day so I plugged my Forscan OBD lappy in and found a few codes and (saved them, shown below) and could clear all but one (P0380)?
However, the EML light then went off and I believe has stayed off since (couple of days now).
I appreciate most these codes could be old but I'll post them all (pre clearing) in case they might suggest to someone something that could do with some closer inspection?
Cheers, T i m
===PCM DTC P0380-68===
Code: P0380 - Glowplug control circuit
Additional Fault Symptom:
- Invalid Signal
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
Glow Plug Circuit
Short circuit
Open circuit.
This DTC may be caused by :
Possible causes are:
Relay control circuit
Glow plug relay
Malfunctioning EDCM
===END PCM DTC P0380-68===
===PCM DTC P0490-E1===
Code: P0490 - Exhaust Gas Recirculation Control Circuit High
- Signal is Above Maximum Threshold
Status:
- Malfunction Indicator Lamp is On for this DTC
This DTC is set when the following condition occurs.
The EGRV position sensor value is consistently higher than the desired set value.
EGR valve short circuit to battery positive.
Exhaust Gas Recirculation Valve
For further diagnostic information refer to the appropriate section of eTIS.
===END PCM DTC P0490-E1===
<snip>
===IC DTC P0000-66===
Code: P0000 - Unrecognized fault code
- Signal is Below Minimum Threshold
Status:
Module: Instrument Cluster
While using DLM, check for the following possible faults:
Check for an intermittent electrical fault.
Lightly wiggle on the component and connector while monitoring signals. Take care not to bend or twist any connector as this will cause damage.
Continue to monitor signals and look for sudden changes in values.
Starting at the component, wiggle and pull each component wire.
Wiggle and pull small isolated sections of the wiring harness.
Inspect connectors for signs of damage, water ingress, corrosion, etc.
===END IC DTC P0000-66===
===IC DTC C1210-0A===
Code: C1210 - Right Front Outlet Valve Coil Circuit Failure
===END IC DTC C1210-0A===
<snip>
