No power
No power
Postby Geoff1979 » Wed Nov 29, 2017 1:01 pm
Hi guys,
My 07 110hp tdci has a problem.
When i rev untill 3000rpm everything is ok
But when i go over 3000rpm to pass some other car i loose my power its like the car has only 50hp
And it takes minutes To go to 3500rpm
Somebody has an idea what it could be?
Thanks!
Geoff1979
Re: No power
Postby Geoff1979 » Thu Nov 30, 2017 1:14 pm
Nobody?
:cry: :cry:
Geoff1979
Re: No power
Postby g-man » Thu Nov 30, 2017 3:48 pm
over 3k revs in any gear?
g-man
Re: No power
Postby Geoff1979 » Thu Nov 30, 2017 10:47 pm
Yes every gear
Geoff1979
Re: No power
Postby mrtn » Thu Nov 30, 2017 10:56 pm
Throttle pedal bad?
1.6 Ecoboost A/T LWB '16
mrtn
Re: No power
Postby Geoff1979 » Fri Dec 01, 2017 9:21 pm
Today i did a little test
When i dont push the throttle pedal completely down its ok
when i push down the floor its hapening again
Could it be the pedal?
Geoff1979
Re: No power
Postby tez » Sat Dec 02, 2017 1:52 am
when did you last service van could be dirty air filter
tez
Re: No power
Postby Geoff1979 » Sun Dec 10, 2017 8:19 pm
Hey guys
I have been sick al week so i bought a new air filter yesterday
Its beter but i still have the problem but now its from 3500rpm
I also found a oil leak the oil is coming from the gasket between the fuelpump and the cam belt pulley :?
Bought a new gasket but its a lot off work and the wheater is to bad for the moment
Could that be the probleme?
Geoff1979
Re: No power
Postby Geoff1979 » Sun Dec 17, 2017 2:15 am
Nobody ever had the same problem??
Geoff1979
Re: No power
Postby g-man » Sun Dec 17, 2017 12:29 pm
had a 110 for 10yr and never had that problem, had plenty of others usually of my making......have u had the codes read
g-man
Re: No power
Postby go2 » Sun Dec 17, 2017 3:05 pm
Try fitting a new fuel filter or seeing if it drives any better
Leaving your fuel cap off
go2
Re: No power
Postby Kenton » Mon Dec 18, 2017 10:19 am
Check all the air hoses for holes, and connection. Also the thin plastic vacuum pipe at the rear of the engine that comes from the side of the EGR valve and round, then goes to a small plastic valve. I had a split in mine and it caused a huge power loss, just would not pull.
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Re: No power
Postby Geoff1979 » Mon Dec 18, 2017 5:15 pm
I had a 90 hp before and i never had any problems
This one already cost me a lot off money this year
I'm going to check and change al you guys tell me and i will post here if its helps
Thanks guys!
Geoff1979
Re: No power
Postby Geoff1979 » Sat Mar 03, 2018 11:06 am
Hey guys
I finally had some time to work on the car
Fuelpump seal has been replaced no oil leaks animore 8) 8)
Changed that little hose Kenton said and its working
Thanks Kenton!
The next job is changing a injector seal who is leaking
At ho much nm you guys tie the injector nuts?
Thanks for the help!
Geoff1979
Re: No power
Postby Geoff1979 » Sat Mar 31, 2018 3:43 pm
Hey guys,
Changed the leaking injector seal today
Chekked the intercoler hoses
Had replaced the air filter and that pressure sensor and little hose kenton mensioned
But i still have that problem
When i pull over 3000rpm the car holds in and i have to change gear
I dont know what to do animore
Do you guys think it will help to go to a shop and hang the car on a computer?
Geoff1979
