Changing fuel filter
Postby travelling man » Tue Dec 05, 2017 6:31 pm
I'm about to attempt this,can one of you experts give me a walk through description,please?
'05 Transit Connect T230 LX TDCi Engine buggered in Spain,replaced with a T200 base 12 plate in white which also buggered it's engine in Spain!
2nd Connect had breakdown insurance and an engine swap, see how long it lasts.....
travelling man
Re: Changing fuel filter
Postby paul2012 » Tue Dec 05, 2017 6:36 pm
Remove all 3 fuel pipes (noting which was the are fitting)
Remove filter. Fill new one full with diesel & fit.
You can either crank engine over until it's starts (no more than 5 seconds a time until engine fires up)
Or fit a fuel priming bulb between main fuel line from tank & filter. Prime fuel system, start engine. once warm up to running temp. Switch off & remove priming bulb & reconnect main fuel line to filter.
Restart engine & drive away :wink:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby travelling man » Tue Jan 02, 2018 5:18 pm
Thank you!
Bought a fuel filter from carparts4you.
Lifted bonnet,located filter,thought bugger that,closed bonnet.
Took van to friendly MoT man,gave him the filter.
Friendly MoT man gave filter to the apprentice,apprentice re-appeared clutching filter and said,'Wrong filter,mate.'
Asked friendly MoT man if he could source correct filter.MoT man said yes,come back tomorrow.
Arrived at MoT garage next day,apprentice fitted new filter,friendly MoT man lightened wallet by £40.
Lifted bonnet,nice shiny filter fitted,van picks up speed much quicker.
Happy bunny.
:D
travelling man
Postby Kenton » Tue Jan 02, 2018 6:13 pm
"Lifted bonnet,located filter,thought bugger that,closed bonnet."
:lol: :lol: My sentiments exactly when i did mine first!
Glad its sweet now though man. 8)
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby spoonman » Thu Jul 12, 2018 7:33 am
paul2012 wrote:[...]
Or fit a fuel priming bulb between main fuel line from tank & filter. Prime fuel system, start engine. once warm up to running temp. Switch off & remove priming bulb & reconnect main fuel line to filter. [...]
Gidday.
I want to change fuel filter on wife's tourneo. Priming bulb has to be on the right connector on my pics, right?
Cheers,
Lars
spoonman
Postby ABA » Thu Jul 12, 2018 12:40 pm
i phoned a gararge the other day to get me a diesel filter gave him my reg and first thing he said witch filter did I have there are 3 ( DER ) pass so he has orderd me all 3 and will send other 2 back when I go and pick it up
ABA
Postby V184 » Sat Jul 14, 2018 10:17 pm
Gidday.
Cheers,
Lars
Remove the water trap & fill the filter with diesel
V184
Postby ABA » Sun Jul 15, 2018 7:56 pm
went back to have mine changed he took one look, took out new filter filled it with diesel got hold of the old one all it took to remove it was a twist and pull down then with the new one push up and twist then start your engine run for a couple of minns job done changed the air filter at the same time seems to be doing more to the gallon now as well
ABA
