Connect 2 oil leaks
Connect 2 oil leaks
Postby johnkent » Sat Dec 09, 2017 8:43 pm
1st one front of the engine as you look in on the right its like a unit with a few heater type sized hoses coming out, seems to be dribbling from the casing of it, what is it and is it involved to change?
2nd one is the small bypass hose at the rear of the engine comes out of the block and joins a pipe from the bottom of the turbo, cant see how to change it as i slid it up and the two pipes nearly join so there's no room to get another one on r put a jubilee clip on it, is there a best way to change this ? cause i cant see how as access is terrible
Lastly a noisy clutch release bearing, does this meant clutch is about to go ?
Any help or advise is appreciated
johnkent
