[FIXED] - Black and white smoke!
Postby JayKay3000 » Sun Dec 10, 2017 12:28 am
Hi Guys.
Black smoke fixed:
Changed clogged fuel filter £40 total from garage
Changed dirty air cleaner £5 from ebay and fitted myself.
White smoke and most of the bucking
Buy 'premium' diesel and mix with red X for diesels. £60 for a tank, £5 for the red X and use half a medium bottle for a tank.
Find the quietest bit of motorway and run the engine past 3krpm for 140 miles
Repeat for another 140 miles.
I tried to get garage to re-code the injectors, but they'd have none of it and I didn't want to spend another £500 to buy and fit injectors on a guess and I reasoned that if the fuel pump was an issue there would be other symptoms. Pretty much lost my faith in garages at this point.
Anyway - No more white smoke or smoke cloud at night, some minor bucking if it runs below 2k rpm when it's cold, but picks up better and feels generally snappier now.
I had a look over the topics and cheers for the help! Injectors were pointed out months ago :roll: and I had a feeling when I got it there was an issue with them. Will see how it goes.
JayKay3000
Re: [FIXED] - Black and white smoke!
Postby karl » Sun Dec 10, 2017 12:39 am
:roll:
what van do you have
connect maybe :?:
so you got pump and injectors done ? :roll:
karl
Tranny Lover!!!
Postby JayKay3000 » Sun Dec 10, 2017 12:45 am
Nah, literally ran red x and premium diesel through the system for 280 miles and sorted it.
After spending 1 and a half years fixing this junk on a super-tight budget I was pretty happy that I finally managed to cure most of engine running issues. Dunno if any of that advice will be any use. Could use a new set of injectors, but honestly not bad enough to need it and I'm trying to save for something better.
JayKay3000
Postby karl » Sun Dec 10, 2017 12:50 am
JayKay3000 wrote:Nah, literally ran red x and premium diesel through the system for 280 miles and sorted it.
nice one
what year is your van mate
:D
karl
Tranny Lover!!!
Postby JayKay3000 » Sun Dec 10, 2017 12:54 am
2005, I need to get the minor oil leak fixed next :roll: Then I can run it on the track :lol:
JayKay3000
Postby karl » Sun Dec 10, 2017 1:05 am
JayKay3000 wrote:2005, I need to get the minor oil leak fixed next :roll: Then I can run it on the track :lol:
you done well mate as these are known for injector faults
these have the Delphi system and from experience after around 130,000, poor servicing and low quality fuel filters they pack up.
i have one sat in Ireland at the minute (cavan) and it wont start well it will with the dreaded sniff then it wont start again after being switch off :( :( and has all the tell tale signs of injectors
but their is no one to bring it back here for me :( :(
karl
Tranny Lover!!!
Postby JayKay3000 » Sun Dec 10, 2017 1:17 am
Shame about the van being stuck in ireland. The injectors do seem to be an issue from various sources and. I hope mine makes it to 130k
JayKay3000
Postby karl » Sun Dec 10, 2017 2:03 am
JayKay3000 wrote:Shame about the van being stuck in ireland. The injectors do seem to be an issue from various sources and. I hope mine makes it to 130k
its stuck on my customers farm in cavan :(
but thats not only the job their either :o their is machines to repairs plus other vans
karl
Tranny Lover!!!
