Identify fuel pipe
Identify fuel pipe
Postby cheers-cochise » Thu Dec 14, 2017 11:41 pm
First post-ever!
I’m struggling to identify a fuel pipe that is leaking on my 2007 1.8 tdci Transit connect. I think the engine is the Lynx diesel 1.8 Duratorq TDCI (90PS). The pipe (?feed pipe) runs to the right of the engine block and has a threaded connection to possibly a filter?
Its leaking at the threaded end and I would like to replace it but can’t even identify it from the various parts diagrams.
Hope one of you geniuses can help?
Thx
Gerry
cheers-cochise
Re: Identify fuel pipe
Postby knobby1 » Fri Dec 15, 2017 12:11 am
Maybe one of these two.?? 9L291A or 9L291B...here:
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
Postby Frag » Fri Dec 15, 2017 12:37 am
The threaded connection you've circled,is not a fuel pipe,
It's the vacuum feed to brake servo.
The only fluid likely to leak from the unit it's connected to,would be engine oil.
Frag
Ford Technician
Postby cheers-cochise » Fri Dec 15, 2017 1:00 pm
Cheers Frag
So it’s not a fuel pipe after all....
That explains why I couldn’t find it
Is that the vacuum unit that it connects into?
Thx
Gerry
cheers-cochise
Postby Frag » Fri Dec 15, 2017 5:34 pm
Yes,brake vac pump is driven via a pushrod,by an eccentric on end of camshaft,
It's oil fed from the head,with a rubber drain pipe from bottom draining back into the block.
If you have a fuel leak,the 'O' rings on ends of fuel leak off connectors to injectors are the most likely cause.
Frag
Ford Technician
