Hi. I e replaced my old 03 plate LWB connect with slightly newer 07 plate. The key fob on new van is broken where the loop is to attach to key ring. It still works ok but is doing my head in as I know I'll loose it at some point.
I know from doing my old van that programming the key fob is piss easy it I've been thinking how useful it would be if I can have the same fob operate both vans. I know it's possible to have more than one fob programmed into the vehicle.
Would one fob work both vans ?? I can't think why it wouldn't work but I no Electrition so does anyone if this will wrk.
