Crank oil seal , pulley end
Postby John Johnson » Sun Dec 24, 2017 7:27 pm
Could some ne confirm a few things ?
The seal is leaking behind the pulley , do I need a tool to remove or lock it ? And can dome one confirm which to order online ? Thanks in advance
It is a 2004 Tdci
John Johnson
Re: Crank oil seal , pulley end
Postby blue estate » Sun Dec 24, 2017 11:58 pm
No need to lock it if shaft seal as that's just the alternator belt , just take starter motor out and jam a large screwdriver in there but also have it in gear and some one with foot on the brakes and undo central bolt #
https://www.eurocarparts.com/ecp/c/Ford ... 4f1&000444
72plt MG 5 ev estate Battery car
blue estate
Postby John Johnson » Mon Dec 25, 2017 12:15 am
Cheers , that's a bit more of a help
John Johnson
Postby John Johnson » Fri Jan 05, 2018 10:29 am
was pretty straight forward in the end with some freeze/shock spray , built it back up and the seal on nthe power steering pump sh1t itself so thats being replaced today . That belt going west certainly tangled round the pulleys and caused chaos ffs
John Johnson
