Hi All,
I am new to this forum but have taken notes as it is a wealth of information on all things transit. Kudos to all you guys in the community for helping each other out.
I have just started using one of my employees old vans for myself on the road. I am an IT technician by the way. I dont carry much tools but in Ireland we are required to have a commercial vehicle for callouts.
Anyhow it is a 2006 Transit Connect T220 LWB High Roof 75PS 1.8 TDDI. When I got it it had an amount of issues which have now been sorted to some extent. Van had no coolant, low on power steering fluid, no radio, turbo hoses leaking all which I have now fixed. It still has an issue with cold starts which I presume are heater/glow plugs which I am going to look at later today. Also the clutch is on the way out.
I have been researching and researching but I have gone through so much information at this point I would like to ask for help. The van was badged as a TDCI and is on the book as a TDCI but it is in fact the older TDDI. I had all my research done banking on that it was a TDCI, even had a 115PS Focus lined up to get the engine, box and ecu out of but that has fallen through now as I am not up for swapping looms and too much messing about.
My everyday car is a 2016 VW Passat 2.0 TDI 150PS so the van is essentially half the power. I want to do everything I can to get a bit more oomph out of that van. I have planned an EGR Delete. I have a friend who is going to remap it to about 120PS. Hard to get rolling road remaps here in Ireland so this guy gets his files from some UK company and I havent had an issue with him in the past. When I am getting the clutch done I was considering changing the box to the focus gearbox as it may better suit my driving. I believe I need the focus gearbox with the speed sensor on it but how will this effect the speed which is displayed on the dash? I know this is a noob question but would the clock be calibrated differently to each gearbox or is it just a case of swap it in and it will be fine? I know you have to swap the selector/linkages but the speedometer I was unsure about.
Any other advice or recommendations would be greatly appreciated?
