57 transit connect 1.8 tdci swb 162000 miles.
So today a mechanic friend of mine in work changed my timing belt , auxiliary belt , water pump and auto tensioner on my van, on returning the van to me he said that the awful noise we could hear is a failing power steering pump.
I know for a fact that before I handed the car to him to change the belt there wasn't any "failing" noise at all.
He said that after replacing the auxiliary belt the noise could be heard but the noise would stop when the belt was removed which would indicate a problem with the power steering pump, I'm not a mechanic so I've not a clue !
Now in hind sight I feel like I should've asked a few more questions but as it is I haven't so I thought I'd ask you guys if you've ever experienced/heard of any similar problems.
I did inspect the engine bay when I got home and I can see that the power steering fluid has gone past the "max" level , I don't know if this is relevant but I thought I should let you's know.
As always any help is greatly appreciated;)
