Transit 2014 reversing sensors
Postby david56 » Mon Jan 22, 2018 9:04 pm
When I put my van into reverse sometimes the center drivers sensor comes on even though there is nothing behind.
I have swapped over the two sensors and briefly it worked as it should but this morning it was the same again. The van has a towing bracket.
Any thoughts.
david56
Re: Transit 2014 reversing sensors
Postby mrtn » Tue Jan 23, 2018 8:28 am
The reversing sensors may get confused if there's an aftermarket tow bar which does not report its existence to the car.
1.6 Ecoboost A/T LWB '16
mrtn
Postby david56 » Sat Feb 17, 2018 2:41 pm
The bumper is a bit warped. Half an hour with a hair dryer seems to have fixed it. Thanks
david56
