Sub woofer power wire - Help!!
Postby k155mda » Tue Feb 06, 2018 11:13 am
Hi All,
I have had a search and tried a number of ideas that has been suggested on this forum for the location of the power cable from the battery through the firewall but no luck :(
I have had the scuttle panel off, grommet out and wire fed through but no luck even when glove box out, floor removed, bottom of the dash off and trying to reach the wire from the other side is impossible but I can hear it clear as day.
Made a hole past the sound proofing behind the inside fuse box but again, trying to feed the wire through is getting me nowhere and it seems like its double skin but how do I get through both sides??
Has anyone got an easier way to wire the power cable up? if so could you send with some pictures as I am baffled.
TIA.
k155mda
Re: Sub woofer power wire - Help!!
Postby Mike » Tue Feb 06, 2018 1:38 pm
What model of Connect?
Mike
Wind up merchant!
Postby k155mda » Tue Feb 06, 2018 1:40 pm
Mike wrote:What model of Connect?
MK1 - 07 plate
k155mda
Postby mrtn » Tue Feb 06, 2018 3:04 pm
I'm pretty sure I ran mine through the wheel well around the A-pillar structure.
1.6 Ecoboost A/T LWB '16
mrtn
