Secondary Power Supply in Back of Van help please
Postby Rossco701 » Tue Feb 06, 2018 5:50 pm
Good evening All, I have had a tow bar man come and wire in the electrics today using a 7 way bypass relay. I was initially looking to take the 12v feed to it from the secondary feed on the right hand side. When he tested it there is no power going to it. Can anyone shed any light as to why this would be the case. Many thanks
Rossco701
Re: Secondary Power Supply in Back of Van help please
Postby doebag » Tue Feb 06, 2018 10:39 pm
Is there a fuse in the corresponding fuseway ?
doebag
Postby Rossco701 » Wed Feb 07, 2018 8:09 am
Yes mate I believe so
Rossco701
Postby John235 » Wed Feb 07, 2018 12:53 pm
According to my info, check to see if F50 is fitted. Middle row of fuses, second fuse from one end. Should be 15 Amp. Power should be on orange wire.
John235
Postby MrTvan » Fri Feb 14, 2020 7:23 pm
Did you solve this issue ?
I have the exact same issue - no power at the aux power plug in the back of the van
MrTvan
