by John235 » Wed Feb 07, 2018 1:10 pm
Do you have one or two sliding doors? Is it the same for both?
If only one, check pin connectors on front edge of door, are they all clean? Also do the pins reach out far enough to contact the mating plate. I had a problem and had to space out the connector to reach.
If that does not work, suspect faulty lock module
