Connect Side Door Help...
Postby Rossco701 » Tue Feb 06, 2018 7:46 pm
Good evening All, I have a 2011 Connect. When unlocking the van with the key fob the side door doesn’t unlock. If I open the side door from inside the van it will open and close from the handle on the outside, as soon as I lock it with the key fob it locks it’s self up and the handle is no longer usable. And help would be greatly appreciated. Many thanks
Rossco701
Re: Connect Side Door Help...
Postby APH » Wed Feb 07, 2018 12:44 am
Are you pressing the unlock button twice quickly?
Andy :D
(\__/)
(")_(")
this is bunny
APH
Postby John235 » Wed Feb 07, 2018 1:10 pm
Do you have one or two sliding doors? Is it the same for both?
If only one, check pin connectors on front edge of door, are they all clean? Also do the pins reach out far enough to contact the mating plate. I had a problem and had to space out the connector to reach.
If that does not work, suspect faulty lock module
John235
Postby Rossco701 » Wed Feb 07, 2018 7:11 pm
Thanks John
Rossco701
Users browsing this forum: Google [Bot], Google Adsense [Bot], John235
